Different experience than GeneratePress Video tutorial
    I realize this video is 4 years old – https://www.youtube.com/watch?v=yq6VcgU3Ufg but I am trying to create a hero section for my blog articles following the same logic and i have a different experience after adding a container as compare to 1:28. There is simply no option to add dynamic content in my Elements section, everytime i set a background image it is a static one. https://imgur.com/a/kGqA3HX
    Note – i have GP premium and GP Blocks premium.
    The option is in the settings panel:
    https://app.screencast.com/XFKLZFHO7FwwW
  • Makes sense, and found that. Thanks!
    Can I follow up with one more question?
    I downloaded and installed this site preset – https://generatepress.com/site-library/ (ARCHIVE)
    On the home-page it has a big featured image and article + 4 others beneath.
    Without making any changes or having any other ELEMENTS presets installed, the page displays differently for me out of the box (https://imgur.com/a/j2NhknL) and I am not sure how to restore the styling from the Archive preset. Did 2 clean installes. Everything else seems fine.
    Also I noticed that whenever I add a looper element, instead of showing 1 element, it shows 2 (or always an extra one). Maybe that is causing the issue.
  • The site template link you provided links to the general site library, which template are you referring to?
    Your current site is built with a page builder. Are you sure it’s the site you’ve implemented the site template to?
  • I’m not 100% sure, sorry I’m new to generate press. but the Site Preset I installed is called Archive, and I did it through Appearance -> Generate Press -> Site Library -> Imported Site -> Archive.
    I also have the Divi page builder plugin installed at the moment, but I’m trying to get rid of it.
    No changes have been made on the main URL rpgwire.com, I am implementing Generate Press through a staging environment https://rpgwire.com/rpg-staging/
  • Ah I see, Archive is the name, sorry I misunderstood it.
    But I’m not able to login to your staging site with the user/password, can you check?
  • I have updated the password, sending again. Just tested and it works for me
  • Please see private message*
  • Can you try removing the imported template, then disable all your plugins except GP Premium, GB and GB Pro, then importing it again?
  • Sure, thank you!
  • You are welcome   🙂
