systrarnanordin
So I have my “Primary menu” set up like this for desktop:
Which works great, however on mobile I want a completely differeny menu, but not this primary menu is what shows up:
Can I somehow change to the mobile menu is another one of my menus?
If you enable the off-canvas menu only on mobile, you can assign a different menu to it. This will act as your mobile menu and can have a different menu than the desktop one.
systrarnanordin
Hi! Thank for the tip!
Where do I change that? Where do I enable the odd canvas only on mobile, is there a menu or with code? -
1. in Appearance > GeneratePress activate the Menu Plus module.
2. then go to Customizer > Layout > Off Canvas:
https://docs.generatepress.com/article/off-canvas-panel-overview/
here you want to set the Off Canvas Panel to Mobile.
Set any other settings you require.3. then in Dashboard > Appearance > Menus you can Add or Edit a menu and set its Theme Location to Off Canvas
https://docs.generatepress.com/article/using-the-wordpress-menu-builder/#setting-a-theme-location
