Directory Website with GP and GB ?
    Wanted your opinion about building a directory website (tourism) with only GP and GB ? What would you be your recommendations? What would you use to build such a website ?
    Do you have an example site in mind so we can gain more info about it?
    Espexially how do you define “directory”?
  • Difficult to give you a specific example, but there is plugins/themes that offers prebuilt stuff that looks like something I want to do like this for example : https://listinghive.hivepress.io/listings/
    But I want to do it from scratch to keep it lightweight.
    A directory is basically a data base you can filter and give you the result you’re looking for. In my case it would feature hotels, tours, restaurants, etc.
  • You will need to use a 3rd party filter plugin if you wish to use GB’s query block to query the custom post types.
    Other than that, it should be straightforward.
  • Thanks, I’m thinking about using the plugin ACPT (Custom post types plugin). Do you know if both ACPT and GP/GB are working well together?
  • I don’t know.
    A more common plugin for that is ACF, and it works well with GP/GB.
