Disable date and author only for posts in specific categories
  • casadellalegalita
    I’m using GeneratePress and I would like to hide post meta (date and author) only for posts belonging to specific categories, while keeping them visible for all other posts.
    For example:
    – Category A → date and author hidden
    – Category B / all other categories → date and author visible
    Is there a recommended way to achieve this in GeneratePress?
    I’m open to using hooks, filters, or custom CSS/PHP if needed.
    Thank you in advance for your help.
  • Please use the following PHP:
    add_action( 'wp', function() {
        if ( has_category( array( 10, 20, 25 ) ) ) {
            add_filter( 'generate_post_date', '__return_false' );
            add_filter( 'generate_post_author', '__return_false' );
    10, 20 and 25 being the category IDs you’re targeting.
  • casadellalegalita
    Thank you very much for your help!
    The suggested solution works perfectly. I implemented the PHP code via a snippet and it now correctly hides the date and author only for posts in the documentation categories, while keeping them visible everywhere else.
    Issue resolved 👍
    Thanks again for the clear and effective support.
  • Excellent, no problem!
