erwinmedia
I’m currently using a Query Loop in GenerateBlocks in combination with the Search & Filter Pro plugin (specifically, a Search & Filter Query) to display filtered post results.
I would like to occasionally insert a promotional block. For example, a container encouraging visitors to sign up for my newsletter, somewhere within the loop. Ideally, this container would appear in a random position each time the page loads, so it feels more organic and less repetitive.
Is there a recommended way to achieve this?
Any guidance or best practices would be greatly appreciated!
Thanks in advance for your help.
Best regards,
Erwin -
It requires custom coding to alter the output of the query, I’m not sure if it’s gonna work, but give it a try.
1. Add a CSS class to the query block, eg.
my-query.
Adding CSS class(es): https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/2. Add this PHP code:
add_filter( 'render_block', function( $block_content, $block ) { static $loopnumber = 1; static $random_insert_index = null; static $loop_instance = 0; static $last_block_id = null; // Detect a new query loop instance (new block or reset) $current_block_id = isset( $block['attrs']['blockId'] ) ? $block['attrs']['blockId'] : md5( serialize( $block ) ); if ( $last_block_id !== $current_block_id && $loopnumber > 1 ) { $loopnumber = 1; $loop_instance++; $random_insert_index = null; // Reset to generate a new random index $last_block_id = $current_block_id; } // Set random_insert_index for the first block of the loop if ( $random_insert_index === null && ! is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'queryloop-insertblock' ) !== false ) { $random_insert_index = rand( 1, 9 ); // Random index capped at 9 } // Process the block if ( ! is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'queryloop-insertblock' ) !== false ) { if ( $loopnumber === $random_insert_index ) { ob_start(); do_action( 'queryloop_insert_hook' ); // Single, consistent hook $insertblock = ob_get_clean(); if ( $insertblock ) { $block_content = $block_content . '<div class="gb-loop-item is-loop-template-item inserted-content">' . $insertblock . '</div>'; } } $loopnumber++; $last_block_id = $current_block_id; } return $block_content; }, 10, 2 );Adding PHP: https://docs.generatepress.com/article/adding-php/
3. Add the content you want to insert into a block element – hook, and set the hook name to
queryloop_insert_hook, set the location to thefront page.Let me know how it goes!
erwinmedia
It worked! Thanks
