Display Location missing on Block Element, Footer
    I’m facing an issue with setting the Display Location with the GeneratePress Element Block.
    Display Location element is not showing when I create a block element and I have not been able to set the location of my site footer.
    Here are screenshots of the issue I am having.
    Generating a new block element
    Empty Block Element with no Display Location
    Block Element Type assigned as Site Footer - no Display Location
    I thought it was possible with the release of 2.0 that by selecting the Element Type ‘Site Footer’ it may automatically set the location to ‘Entire Site’ on publishing but this isn’t the case. Please see screenshots below.
    Drafted Site Footer is Published but has no set location
    Default GeneratePress footer is still displayed
    Many thanks for your help.
    The Display Rules settings are located at the bottom of the editor. It looks like the meta box is currently collapsed or hidden, so you may need to drag it up or expand the section to access it: https://cln.sh/9YXhRdpV2N7D7LKhDqml
