Display multi-day events correctly on events calendar
  • Hi
    I’m bullding a simple events calendar using Generate Blocks and Advanced Custom Fields with 2 date fields:
    event_start_date – mandatory
    event_end_date – optional for use with multi-day events
    To control the query loop I’ve used the nifty PHP Snippet and CSS class you provided here:
    https://generate.support/topic/creating-an-upcoming-events-page-with-query-loops-date-handling/
    This works a treat except for multi-day events which drop from the display before the event end date has been reached.
    Is there a way to add a “event is visible until event_end_date is expired” command using the optional event_end_date field?
    Try this PHP code:
    add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) {
        // Apply filter if loop has class: custom-event-query
        if (
            ! is_admin() &&
            ! empty( $attributes['className'] ) &&
            strpos( $attributes['className'], 'custom-event-query' ) !== false
            // Current date in WordPress timezone.
            $today = current_time( 'Y-m-d' );
             * Show an event when:
             * 1. It has an end date and the end date is today or later
             * OR
             * 2. It has no end date and the start date is today or later
            $query_args['meta_query'] = array(
                'relation' => 'OR',
                // Event has an end date that hasn't passed.
                array(
                    'key'     => 'event_end_date',
                    'value'   => $today,
                    'compare' => '>=',
                    'type'    => 'DATE',
                // Event has no end date, so start date must be today or later.
                array(
                    'relation' => 'AND',
                    array(
                        'key'     => 'event_start_date',
                        'value'   => $today,
                        'compare' => '>=',
                        'type'    => 'DATE',
                    array(
                        'relation' => 'OR',
                        // End date doesn't exist.
                        array(
                            'compare' => 'NOT EXISTS',
                        // End date exists but is empty.
                        array(
                            'value'   => '',
                            'compare' => '=',
            // Order events by start date.
            $query_args = array_merge( $query_args, array(
                'meta_key' => 'event_start_date',
                'orderby'  => 'meta_value',
                'order'    => 'ASC',
        return $query_args;
    }, 10, 2 );
  • Works great. You’ve made a nifty PHP Snippet even niftier – and saved me faffing about with a complex calendar plugin for a simple task.
    Thanks.
  • You are welcome   🙂
