Displaying ACF Image Galleries and Repeater Fields in Query Loop
    Is it possible to display both an ACF image gallery and an ACF repeater field within a GenerateBlocks 2.0 Query Loop without needing to write any additional custom code? If so, could you show me how to set it up?
    Thank you.
    It should be able to, but I haven’t tested it yet myself.
    What it the relationship between the gallery and the repeater? Is the gallery a sub field of the repeater?
    Or you can provide your admin login for me to check the structure.
  • Hi
    Sorry for the confusion. What i meant is two separated questions
    1. I made a Content Template element for a CPT and want to use Text element or Image element to display all images from an ACF gallery field. Is it possible?
    2. I also have ACF repeater fields in this CPT so how to display all repeaters content including its subfields?
    Thank you
    Both fields are now supported in the V2 Query block. Here’s how to configure them correctly:
    ACF Gallery field:
    – Add a Query Loop block, set the Query Type to Post Meta, and enter the gallery field name in the Meta Key field.
    – Inside the Loop Item block, add an Image block and use the dynamic tag {loop_item key:url} in the Image field.
    ACF Repeater field:
    – Add a Query Loop block, set the Query Type to Post Meta, and enter the repeater field name in the Meta Key field.
    – Inside the Loop Item block, add a Text block for each subfield within the repeater. Use the dynamic tag {loop_item key:subfield_name} (replace subfield_name with the actual subfield name). For multiple subfields, add corresponding Text blocks for each.
  • Thank you very much it’s working.
    I have another scenario using query loop to to display Room CPTs inside Content Template of a Cruise CPT.
    Inside each Room block, i also need to display room images (ACF gallery field). Is it doable?
    Looks like i need a nested query loop inside?
  • Yes, in this case, you need to add another Query block for the Gallery field inside the Room Query block.
