Yolanda Lippens
Hello great support,
Is it possible / How can I make 3 columns with a text that is divided and connected at the same time?
So the end of column 1 automatically continues in column 2, and 2 continues in column 3.Like this example:
https://i.postimg.cc/7hLYLbXp/20230608-001000.jpgIn Word it’s easy to make, but my client wants this in WP, but I have never seen it before, nor in any setting.
Do you have any idea if this is possible, if so, how?
Thank you again!
Yolanda, NL -
Unfortunately, it’s not that easy.
You might need to write custom Javascript to make it work in this way.
I would recommend looking for a plugin first, there might be a plugin which does this.
Yolanda Lippens
That’s exactly what I thought also.
I will check for plugins, but to be honest, I don’t want to install extra plugins for this kind of lay-out wishes.Thank you for your quick response!
