Does GenerateBlocks use jQuery?
    Does GenerateBlocks use jQuery in any way, anywhere?
    Can I completely disable this mess from my front-end? 🙂
    GenerateBlocks does not have any dependencies with jQuery. Also, the free GeneratePress theme itself doesn’t use any jQuery and the only option that requires jQuery in the premium plugin is the sticky navigation.
    If you are using the GeneratePress theme and the sticky navigation without transition effect then we can actually replace it with CSS.
    Hope that helps.
  • Thanks
  • No problem!
