Bob123
I’m using the Donate template.
The hero background image appears to have a wave-type shape at the bottom that I want to remove. I want the bottom to show the full image and be a straight line for the image.
I thought this could be fixed using the shape divider, but that didn’t work. I also tried to use some CSS, but that didn’t work either. I didn’t see an element for the hero image either.
How do I fix it so the hero background image has no other shape to it than the normal rectangle of the image itself?
Your help would be greatly appreciated.
You just need to select the shape block in the first root container and delete it:
https://app.screencast.com/hhCvKwT62ZV0w -
Bob123
Hi Ying:
That fixed it.
Thanks so much… I really appreciate your help with this!
Bob
