download at https://drole-de-voyage.fr/x.html
  • Hello, I need to add the x.html file to my root folder so that it can be downloaded at https://drole-de-voyage.fr/x.html How to do it? Thank you
    It’s not something you can do from the theme. follow the steps below, if it doesn’t work, please check with your host:
    1. Locate the Root Directory:
    – Access your website’s root directory via FTP, SFTP, or your hosting control panel’s File Manager.
    – The root directory is typically named public_html, www, or similar.
    2. Upload the x.html File:
    – Place the x.html file directly into the root directory.
    – Ensure the file is named exactly x.html (case-sensitive).
    3. Check File Permissions:
    – Ensure the file has proper permissions for public access, usually 644 (readable by everyone).
  • Thanks, it is ok now !
  • Glad to hear that 🙂
