Drop Down Menu not getting hidden once clicked
    Dropdown not getting hidden when we click on it and then move to other dropdowns. You can visit this video: https://dev.ruminatee.com/azad/wp-content/uploads/2025/10/Recording-21-2.mp4
    Website url: https://dev.ruminatee.com/azad/
    Please let me know how to fix this.
    Regards
    I can replicate the issue, it’s becuase when clicking on the parent menu item, GP adds the sfhover class to it to open the sub menu.
    Try adding this JS to a hook element, and set the hook name to wp_footer, set the location to entire site.
    <script>
    document.querySelectorAll('li.menu-item-has-children').forEach(function(el) {
        el.addEventListener('mouseleave', function() {
            el.classList.remove('sfHover');
    </script>
    Let me know if this helps!
  • Hi Ying,
    Thank you for the quick update. I have added the code snippet provided by you. This works partially.
    You can check and understand what i meant to say.
    Regards
  • In this case, remove the JS and add this CSS instead:
    .main-navigation:not(.toggled) ul li.sfHover:not(:hover)>ul {
        display: none;
