tonylee189
Hi! The drop menu not displaying on mobile. Please refer to jzminimalist.com (The parent menu is “Shop All”). Can you help? Thanks.
And also, I’ve tried https://docs.generatepress.com/article/building-simple-mega-menu/ in order to create a mega menu, but looks like it didn’t work and also not display responsibly on mobile.
Please help. Thanks.
tonylee189
What is the color you set for cusotmizer > colors > Off Canvas Panel > Sub-Menu Text?
If it’s white, change it to another color.
If it’s not the issue, please link me to your site.
tonylee189
It works. Thanks.
I tried following the instructions from https://docs.generatepress.com/article/building-simple-mega-menu/ to create a mega menu, but it doesn’t seem to be working. I noticed there’s some other code in the ‘Additional CSS’ section—could there be a conflict between them?
Below is the code that comes with the theme.
/* GeneratePress Site CSS */ /* adds a white border around the entire site on tablet and desktop */ @media (min-width: 769px) { body { padding: 0 30px 30px; } .site-footer { margin-top: 30px; } } /* woocommercce product page "select options" button size adjustment */ .woocommerce ul.products li.product .button { width: 100%; text-align: center; padding: 3px; } /* woocommercce price, option and the description font weight */ body.woocommerce div.product .woocommerce-tabs ul.tabs li a { font-weight: 200; } .price .woocommerce-Price-amount.amount { font-weight: 200; } .woocommerce div.product form.cart .variations label { font-weight: 200; } .wc-pao-addon label.wc-pao-addon-name { font-weight: 200; } /*woocommerce cart and checkout page font weights*/ table th, table td, table strong, dt, .woocommerce table.shop_table :is(th, td), .woocommerce ul#shipping_method .amount, .woocommerce-error a, .woocommerce-info a, .woocommerce-message a, #payment .payment_methods li.wc_payment_method > input[type=radio]:first-child:checked + label, .woocommerce #payment #place_order, .woocommerce-page #payment #place_order { font-weight: 200 !important; } /* Side bar products titles font weight */ .product_list_widget li a span { font-weight: 200; /* image block drop shadow */ .photo-shadow img { box-shadow: 10px 10px 0px rgba(237,235,235,0.8); } /* product additional information tabs font styling */ .woocommerce table.shop_attributes th { font-size: 16px; } .woocommerce table.shop_attributes td p { padding: 8px 16px; font-size: 16px; } /* End GeneratePress Site CSS */Below is the mege menu code found in https://docs.generatepress.com/article/building-simple-mega-menu/,
/* Mega Menu */ @media (min-width: 769px) { nav .main-nav .mega-menu { position: static; } nav .main-nav .mega-menu > ul { position: absolute; width: 100%; left: 0 !important; display: flex; flex-wrap: wrap; } nav .main-nav .mega-menu > ul > li > a { font-weight: bold; } nav .main-nav .mega-menu>ul>li { display: inline-block; width: 25%; vertical-align: top; } nav .main-nav .mega-menu.mega-menu-col-2>ul>li { width: 50%; } nav .main-nav .mega-menu.mega-menu-col-3>ul>li { width: 33.3333%; } nav .main-nav .mega-menu.mega-menu-col-5>ul>li { width: 20%; } nav .main-nav .mega-menu > ul > li:hover > a, nav .main-nav .mega-menu > ul > li:focus > a, nav .main-nav .mega-menu > ul > li[class*="current-"] > a, nav .main-nav .mega-menu ul ul { background-color: transparent !important; color: inherit; } nav .main-nav .mega-menu ul .sub-menu { position: static; display: block; opacity: 1; visibility: visible; width: 100%; box-shadow: 0 0 0; left: 0; height: auto; pointer-events: auto; transform: scale(1); } nav .main-nav .mega-menu ul.toggled-on .sub-menu { pointer-events: auto; } nav .main-nav .mega-menu .sub-menu .menu-item-has-children .dropdown-menu-toggle { display: none; } } /*End mega menu*/ -
There don’t appear to be any direct conflicts in the CSS. Could you elaborate a bit on what isn’t working?
tonylee189
Hi! When I deleted the first part codes /generatepress…./ and kept the /mega menu…/ codes, it will display like this https://ibb.co/nk6tsG0, this is what we want.
But if I added the first part codes /generatepress…./ and kept the /mega menu…/ codes at the same time, it will display like this: https://ibb.co/34M4h8P, this is NOT what we want.
I think if there may be some problem with the existence of both? Thanks.
tonylee189
the site url is jzminimalist.com. The mega menu is located under “Shop All”.
Could you provide a temporary login so I can take a closer look at the CSS in the Customizer?
tonylee189
Already sent it.
The issue is not the CSS function in the 1st part of CSS, it’s because there’s a syntax error, it’s missing a closing bracket
}, so any CSS below that won’t work, including the mega menu CSS.
https://app.screencast.com/AF0I1RUKDxZofAdding the
}should fix the issue.
