trhynard
My dropdown menu is not showing all of a sudden. You can see here: https://michiganmaple.org. It appears the menu is hidden behind the hero image, as if I manually adjust the positioning, can can see them menu when it’s above the hero image.
trhynard
It works fine in the editor, but not on the live site
Can you try adding this CSS?
nav#site-navigation { position: relative; }
trhynard
That fixed it, thank you! Can I ask why that manual change is necessary?
It’s because the 1st container has the background image attached to the pseudo-element, which makes it sit on a higher spot, so the dropdown menu is hidden underneath the background image.
trhynard
Thank you!
No Problem 🙂
