dynamic accordion fields
  • Hello, I want to create a section of a website implemented with ACF fields, a title field, and an internal section with text and links, arranged in an accordion layout. My question is, can I use the GenerateBlock Pro accordion for this behavior? Since it’s built with dynamic content, I don’t know if this behavior is possible or if I should implement it with an external library. Thanks in advance.
    https://ibb.co/CSJ8dd4
    I don’t recall ACF has a title field, can you tell me the exact name of the field?
  • Hello, I would take the title directly from the CPT. What I want to know is if the accordion or tab block can dynamically handle dynamic elements. For example: I create a new post in the CPT, and could it be reflected in the accordion or tab as a new item with its title and internal item? Thank you.
  • I create a new post in the CPT, and could it be reflected in the accordion or tab as a new item with its title and internal item? Thank you.
    Yes, it could 🙂
  • Thank ying.
  • You are welcome   🙂
