Dynamic Archive Title Disappears Without Post Assigned To That Category
  • I have created an all archives page hero element. I have added a headline and clicked on the dynamic options and selected title to pull in the title of the category. This works fine when there is a post assigned to that category but when there are zero posts assigned that category, the category title doesn’t show at all.
    Is there a way for the category title to show dynamically on archive pages even if there aren’t posts assigned to it yet?
  • Thanks for your fast reply. I did try that but it seems I am then unable to style the shortcode. Is there another solution please?
  • Try adding a GB Headline Block with class get-archive-title. Adding Custom Classes: https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
    Then, add this code:
    add_filter('generateblocks_dynamic_content_output', function($content, $attributes, $block){
    	if ( ! is_admin() && ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'get-archive-title' ) !== false ) {
    		if(! $content){
    			return get_the_archive_title();
    	return $content;
    }, 10, 3);
  • Thanks again. I followed your instructions with both, cleared the cache but still not title. Have I missed something?
  • Could you share admin login credentials? I’ll check why it isn’t working.
  • Thanks. As requested in the private area.
  • Disable the dynamic option feature. Just any text.
    Then, replace the PHP snippet with this:
    add_filter( 'render_block', function( $block_content, $block ) {
        if ( !is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'get-archive-title' ) !== false ) {
    		$myreplace = '/>(.*?)<\/h1>/s';
    		$myinsert = get_the_archive_title();
            $block_content = str_replace( $myreplace, $myinsert , $block_content );
        return $block_content;
    }, 10, 2 );
  • Thanks, is this snippet instead of the previous one, or in addition?
  • Replace the previous one with that.
  • After following those instructions, all I see now is the text that I have replaced it with instead of the dynamic title.
  • I replaced it with this:
    		$myreplace = 'TEST';
    }, 10, 2 );
    I just used the static text you added – TEST – as the identifier.
  • I understand now thank you. It does however pose another challenge in that I am now not able to use the before text feature as I was doing in the dynamic option.
  • You can modify the code to this:
    		$myinsert = 'YOUR BEFORE TEXT HERE ' . get_the_archive_title();
    }, 10, 2 );
  • Thank you, that worked great.
  • You’re welcome!
