Dynamic Archive Title showing first post title in loop instead
    I am not sure why my archive titles are showing the title of the first post in the query loop instead of the category/archive name. I have tried adding the dynamic title in both a separate Hero block element and inside the Loop template.
  • Hi Milozzz,
    Can you share admin login credentials through the Private Information field? I’ll check your setup and see what’s causing the issue.
  • Hi Fernando, yep. the admin creds should be the same as the folder authorization creds. Also just updated in the fields.
    edit that Headline and remove the Dynamic Data options in the block settings sidebar.
    And instead use the GP Dynamic Data options:
    https://docs.generatepress.com/article/dynamic-data/
    Those settings know its an archive page so it swaps the title accordingly.
    We will be updating GB to handle that too in the future
  • Gotcha, thanks a lot David.
  • You’re welcome
