dynamic category filter for blog
  • Hi GeneretePress-Team,
    I have a blog archive page on my website that displays all posts in a four-column layout. I’d like to add a category filter to this page. There is a content template element to style the appearance of the archive page.
    Above the posts, I want to display one button for each existing category (ideally generated dynamically, so that a button is automatically created when a new category is added).
    When one of the buttons is clicked, only posts assigned to that category should be shown.
    I found a similar filter function on the “Dispatch” demo site. Unfortunately, I can’t install the demo from the site library to see how it was implemented there (it’s not available in the library).
    https://gpsites.co/dispatch/category/time-saving/
    Thanks a lot!
    The categories on the dispatch template is NOT dynamic, it’s just a secondary menu, the menu is created manually.
    You are using WP category list block, it is a better option.
  • Thank you for your reply.
    So using the category list block and styling with additional css is the way to go? Like it is in the “read” demo site?
  • So using the category list block and styling with additional css is the way to go?
    Yes, it is 🙂 I made the Geek template, the category list was added in this way, it’s the only way to make it dynamic.
