eluyawi
Now, I know what you means.
I want the block Elementos appear here (where is the arrow in the screenshot). (It would be the last block before to start te footer)
OK,
In the element list you can use either:
after_main_content
orbefore_footer
eluyawi
Ok,
I have used “
after_main_content
” in both Elements with the same priority. Yo can take a look to the screenshot.https://share.zight.com/GGuBD8l4
https://share.zight.com/wbux2rzxWill these elements change depending on the parameters defined in the snippet I have created?
add_filter( ‘generate_element_display’, function( $display, $element_id ) { if (function_exists(‘rcp_count_memberships’)) { $total_suscriptores = rcp_count_memberships(array(‘status’ => ‘active’)); $total_suscriptores = 101; //101 if($total_suscriptores <= 100 && 3474 === $element_id){ $display=false; }elseif( $total_suscriptores > 100 && 3492 === $element_id) { $display=false; }//fin_else } return $display; }, 10, 2 );
Yes, that Snippet should now work.
Have you tried adding it ? -
eluyawi
Yes, but for example when I change the parameter “total_suscriptores” to “0” or “101”, a lot of times Doesn’t show the block at the moment, Could it be the server cache? or what do you think it could be.
It could be a caching issue.
Does the problem go away if you disable all caching ? -
eluyawi
Exactly.
I have deactivated the LiteSpeed Cache plugin and the change are made immediately.
Any suggest or idea? -
You will need to ask LiteSpeed support on how to eliminate that as I have no idea how their page caching works.
