dynamic featured image in header element with title
  • I was creating a header element that i want the featured image to show behind a gradient overlay with the page title on top of that. Ive created the dynamic title and set the featured image to be a dynamic background on the container but the image does not show up?
    and i dont know how to apply a darkened opaque grey overlay if that makes sense to make the featured image darker so the title text shows more clearly.
    thanks!
    using GP premium and GB pro on this site.
    The featured image url is empty, can you make sure a featured image is set for the page?
    If so, can you provide an admin login for me to check the backend setup?
  • thanks! yes a featured image is set (see screenshot link attached )
    The featured image isn’t showing up because the Image Key in the dynamic tag is currently set to alt — it should be set to url for the image to display correctly.
    To add a gray overlay, select the container and add another background type (Overlay) under the Backgrounds panel. Then, choose a gray color and reduce its opacity so it appears semi-transparent on the frontend instead of solid.
  • oh shoot ok thanks,
    now how to i prevent the overlay from greying out the title text as well?
  • It shouldn’t affect the title text. Can you try changing the text color to a brighter one?
  • yea you are right im not sure what i was doing! thanks
  • No problem! 🙂
