Dynamic Headline in Loop template not rendering
  • I have a post category archive for which I created a Loop Template. At the top I added a Headline block with dynamic title. My display rule for the category works. However, the Headline is only rendering when there is at least 1 post in the category. When there are 0 posts in the category, the Headline block is not rendering.
    Is this a bug or feature?
    That is expected behavior. The archive page needs to have at least one post for the title to appear, otherwise it will be classified as a “no results” page.
  • I see. Is it possible to configure a Loop Template to not be applied to “no results” pages?
  • You can try exclude the no results page from the loop template element’s location, however, there will still be no title if no posts are published.
  • OK thanks!
  • No Problem 🙂
