Dynamic Hero Header Image from Featured Image
  • Sorry, closed too early…
    Just now I build this block with the V2, but don’t work…
    Put in the field “Background Image” {{featured_image key:url}} -> changed to featured_image key:url
    https://postimg.cc/fSyzVmCH
  • You need to add it under the Inline Background Image field in the Settings panel. See here: https://cln.sh/hqhcp3f31ZnfMPx0wVVB
  • Ok, that works now… but can I then also select the position of the section with this action? top, center, bottom? I can see that at the Backgrounds/Background Type/Background Image field has been automatically filled with var(–inline-bg-image), right?
    In Media Size I have moved the point for the section, but it has not changed anything.
  • Yes, you can set the background position in the backgrounds panel.
    As for the media size option, it is only available for a static background image, unfortunately!
