inzpyre.me
I was able to create a CTA before the footer for both pages and posts to show further blog posts and resources.
However, the widget/loop CTA for the posts looks only good on posts themselves and some pages. I included some examples below to show you what I mean. I have already invested several days to find out what makes the difference here: unsuccessful so far. What am I missing? Do you have any ideas?
Thank you so much for your support.
is the section with the title of:
WEITERE RESSOURCEN
As I see that on all URLs provided and they all look the same. -
inzpyre.me
Hi David, no it is the section right before “Weitere Blogbeiträge”.
Thanks for your input.
Ah ok.
Edit that element, and select the top most Container Block and duplicate it. So now there are 2 copies of that CTA. Then delete the original version. Save that changes and let me know -
inzpyre.me
Well, I’m suprised it was that simple to do the job. Thanks! Everything fine now.
FYI
When you copy a Block from one post to another , including into an element, GB can’t reset the unique class IDs at the moment. So the two blocks end up sharing classes that results in the styles being overwritten.
Making a duplicate of the block fixes the issue.
In the next version of GB this hopefully will no longer be a thing.Glad to be of help
