Dynamic Taxonomy List items as separate blocks
  • Hi there, I saw a few posts on this but not exactly what I was looking for.
    So in older versions of GenerateBlocks I was able to add a button, add dynamic data to that button, choose taxonomy list and then that would create one button per term. This way I could have a list of separate elements that I could arrange using a div with display:flex and I used it in all my blog posts.
    I have tried to do that for a new design and I discovered that 1.Term List is not available for buttons, and 2.For text block it is available but it renders as a single block with any separator that I choose (commas, spaces…).
    Sample Image
    I’m I missing something? Is there any way I can achieve this now with this version?
    Thanks.
    Yes, you can achieve it with v2 text block.
    When you set the term list dynamic tag for the text block, set link to to Term, so it will add a link to each term.
    Then select the text block, click the Links selector, set some paddings and background color, each term will become a button as the screenshot.
    To add space between the term buttons, select the text block, set its display toflex, and give it a column-gap.
  • Thanks a lot for the quick reply! It worked perfectly 🙂
  • Glad to hear that 🙂
