Shibumi
Hi GB team!
I’m trying to add a custom icon for each term in a dynamic term list.
With the previous version of GB I was able to do so manually with css by targeting the specific class that the block added to each span. Here’s an example:<p class="gb-headline gb-headline-355c1760 gb-headline-text dynamic-term-class"> <span class="post-term-item term-termico">Termico</span> <span class="post-term-item term-durevole">Durevole</span> <span class="post-term-item term-easy-care">Easy care</span> <span class="post-term-item term-lana">Lana</span> <span class="post-term-item term-morbido-e-avvolgente">Morbido e avvolgente</span> <span class="post-term-item term-traspirante">Traspirante</span> </p>With the new version of GB though it seems that the “post-term-item” class and the specific class “term-XXX” are gone. Like this:
<p class="gb-text senza-pag-prodotto gb-text-868520f6"> <span>Senza Glutine</span> <span>Senza latte</span> <span>Senza nocciole</span> <span>Senza zuccheri aggiunti</span> <span>Vegan Friendly</span> </p>Is there a way to add them OR an easier way to add a custom (svg) icon for each term?
Lorenzo -
Try this PHP snippet, but you will need to assign the term link to the terms, so each term is an
<a>, as the<span>doesn’t work with this filter.add_filter( 'term_links-category', 'add_category_class_to_term_links', 10, 1 ); function add_category_class_to_term_links( $list_items ) { foreach ( $list_items as &$item ) { // Extract the term name from the <a> tag if ( preg_match( '/>([^<]+)</', $item, $matches ) ) { $term_name = sanitize_html_class( $matches[1] ); // Sanitize term name $class = 'post-term-item term-' . strtolower( $term_name ); // Force lowercase // Check if the class attribute exists if ( strpos( $item, 'class="' ) === false ) { // No class exists, add it $item = str_replace( '<a ', '<a class="' . esc_attr( $class ) . '" ', $item ); } else { // Class exists, check if our class is already present if ( strpos( $item, $class ) === false ) { // Append the class if it’s not already there $item = preg_replace( '/class="([^"]*)"/', 'class="$1 ' . esc_attr( $class ) . '"', $item ); } // If the class is already present, do nothing } } } unset( $item ); // Unset the reference after the loop return $list_items; }Adding PHP: https://docs.generatepress.com/article/adding-php/
Shibumi
Hi Ying,
thank you for your reply.
Unfortunately it seems not to be working.
I converted the<span>in<a>as you suggested, but the result is as follows:<p class="gb-text senza-pag-prodotto gb-text-868520f6"> <a href="https://dev.laperladitorino.it/allergeni/senza-nocciole/" rel="tag">Senza nocciole</a> <a href="https://dev.laperladitorino.it/allergeni/vegan-friendly/" rel="tag">Vegan friendly</a> </p>Lorenzo
Try this snippet:
add_filter('generateblocks_dynamic_tag_output', function ($output, $options) { if (isset($options['term_class'])) { if (strpos($output, '<span>') !== false) { // Use a regular expression to find all spans and their content $pattern = '/<span>(.*?)<\/span>/'; preg_match_all($pattern, $output, $matches); if (!empty($matches[0]) && !empty($matches[1])) { // Loop through each match and replace with span + classes foreach ($matches[0] as $key => $original_span) { $term_text = $matches[1][$key]; $term_slug = sanitize_title($term_text); // Convert to slug format // Create the new span with both classes $new_span = '<span class="post-term-item term-' . $term_slug . '">' . $term_text . '</span>'; // Replace in the output $output = str_replace($original_span, $new_span, $output); } } } } return $output; }, 10, 2);Then, add the
term_classoption to the Term List dynamic tag so it looks like this:
{{term_list tax:category|term_class:true}}This works only with the term list without a link.
Shibumi
Hi Alvind,
works like a charm!Are you anyway going to embed the class in the new GB as the old one in a next update?
It was really useful!I’ll open a new thread for an easy way to add an icon to a term without CSS 🙂
Lorenzo -
There are no plans for this at the moment, but we’ll see what improvements we can make in that area.
Shibumi
Hi Alvind,
Hope everything is good.After an update the script doesn’t work anymore. Could you help me out please?
Shibumi
Sorry, my bad. I forgot to edit the dynamic tag.
Glad to hear that 🙂
