webfresh
Hi
I have a custom post type of logos
The logos are assigned a categoryI have created an element which is a query on the logos to select all logos with a specific category, by using TAXONOMIES and SELECT TERMS
This works
But I want to hook the element to each of my product pages and only show the logos relevant to that product page based on the category that is appropriate for that page.
I use ACF and my thought was for each product page, to populate an ACF field that contained the category value and then somehow use that value in the query.
Is there a way to alter the ‘SELECT TERMS’ value of the query in some dynamic way to match the category for the product page it is on.
I’m happy to use PHP
You can use the approach above. Then try adding this PHP snippet:
add_filter( 'generateblocks_query_wp_query_args', function( $query_args, $attributes, $block, $current ) { $category = get_post_meta( $current['post_id'], 'your_custom_field_key', true ); if ( empty( $category ) ) { return $query_args; } if ( ! isset( $query_args['tax_query'] ) ) { $query_args['tax_query'] = []; } $query_args['tax_query'][] = [ 'taxonomy' => 'your_cpt_taxonomy', 'field' => 'slug', 'terms' => $category, ]; return $query_args; }, 10, 4 );Replace:
your_custom_field_key— the custom field meta key on the product page.
your_cpt_taxonomy— the taxonomy slug of the Logos CPT’s categories.
slugin'field'— change tonameorterm_iddepending on what the custom field stores.Make sure you don’t add any parameters to the Query block.
webfresh
Thank you so much – this is brilliant!!!!!
Just wondering whether I should be checking I’m on a product page first??
I realize that $category won’t have a value if I’m not on a product page but wondering if it would be more efficient to check first?Also – a caveat for anyone else following along, I had more than one query on my page so I had to check I had the right query before updating the $query_args
I checked this value: $attributes[‘query’][‘post_type’][0] to see if it matched my logos custom post type.
Oh and by the way, my query was inside a carousel and all still worked OK!
Alvind’s code does check if
$categoryhas values first by this piece:if ( empty( $category ) ) { return $query_args; }Do you want to check if it’s on a product page first?
webfresh
Hi Ying
Sorry my question was a bit ambiguous
I said ‘would it be more efficient to check first’ – meaning check that it was a product page first
So I’m asking if it would be more efficient to check if it is a product page first
In that case, you can add a custom class of
logos-cpt-queryto the Query block under Advanced > Additional CSS Classes, then use this updated snippet:add_filter( 'generateblocks_query_wp_query_args', function( $query_args, $attributes, $block, $current ) { if ( empty( $attributes['className'] ) || strpos( $attributes['className'], 'logos-cpt-query' ) === false ) { return $query_args; } $category = get_post_meta( $current['post_id'], 'your_custom_field_key', true ); if ( empty( $category ) ) { return $query_args; } if ( ! isset( $query_args['tax_query'] ) ) { $query_args['tax_query'] = []; } $query_args['tax_query'][] = [ 'taxonomy' => 'your_cpt_taxonomy', 'field' => 'slug', 'terms' => $category, ]; return $query_args; }, 10, 4 );This way, the snippet will only apply to that specific Query block.
If the Element’s Display Rules location is already set to Product Pages, that additional condition wouldn’t be necessary, since the Element will only display on product pages anyway.
webfresh
Thanks Alvind – perfect! Thank you so much for your excellent support.
You’re welcome! 🙂
