Edit Global Styles: In like a master file format?
  • Hey Team, 👋
    I’m using GeneratePress with GenerateBlocks Pro and have a question about how Global Styles are managed.
    I’m wondering whether there is a way to access or edit the underlying “master” CSS source directly, rather than editing each Global Style individually through the interface (which is massively inconvenient if you know what you want.)
    Specifically, I’d like to know:
    Is there a master CSS file that GenerateBlocks uses or generates, and can it be edited?
    Is there a supported method to export, import, or manage all Global Styles as CSS rather than through the UI alone?
    Thank you.
    Not currently possible. Global Styles are saved as a post type, each style is an individual entity. You can import/export global style from the WP import/export function, though.
  • Noted, any idea if this feature is in the works? / Can it be?
  • With GB 2.3.0-beta.3 and GBP 2.6.0-beta.3. You can now edit the CSS of the global styles/block styles directly instead of via the interface. But there isn’t a master file; you will still need to edit them one by one.
    Here’s a screenshot for your reference:
    https://app.screencast.com/iYNE1NSJsKjpb
  • Ah, that’ll make it much easier, it would be awesome if we could edit the global styles in one central file so hopefully that feedback can be passed up the chain. That being said, I’m delighted to be able to edit these one by one also, this should help massively, thanks Ying. 👍
  • You are welcome   🙂
