Editing layout i WC Single Product Page
  • Hi there
    I’m trying editing the layout of WC Single Product Page from scratch, and I’m using GP Element Block, where I’m using shortcodes from below snippet – I have set Displays rules pointing on Products.
    I’m nearly get it working, but get an error “Update failed” when saving Elements Block, using below snippet.
    It is working when I exchanges “woocommerce_show_product_images” with for example “woocommerce_template_single_price”.
    Snippet to insert shortcode in GP Element Block
    function single_product_column_1() {
    // Start output buffering (optional, useful if your hooked functions echo content).
    ob_start();
    do_action( ‘wc_single_product_column_1’ );
    return ob_get_clean();
    add_shortcode( ‘sc_single_product_column_1’, ‘single_product_column_1’ );
    remove_action( ‘woocommerce_before_single_product_summary’, ‘woocommerce_show_product_images’, 20 );
    add_action( ‘wc_single_product_column_1’, ‘woocommerce_show_product_images’, 20 );
    Hope you can help 🙂
    please check with Woocommerce’s support for this, your code might have some issue.
  • I’ll try that 🙂
  • Hope they can fix the code for you 🙂
