erickimani
How do I go about making changes to the categories page on generate press.
Hi Erickimani,
What sort of change are you looking to make? Are you wanting to change how posts appear for instance? If so, this article should help: https://docs.generatepress.com/article/block-element-content-template/
erickimani
https://share.getcloudapp.com/qGu61no7
Sorry this link doesnt seem to be helpful when I click it. Is it the correct one
Sorry, I pasted the wrong link. I corrected it now. Can you check my response above?
erickimani
Thanks for this.
I would like to be able to get teh categories to be orded according to modified date but I dont see where to set this up
This is teh setup I have ont he element
Try adding this snippet:
function my_custom_ordering( $query ) { if($query->is_main_query() AND !is_admin() ) { if ( $query->is_home() || $query->is_category() || $query->is_tag() ){ $query->set( 'orderby', 'modified' ); } } } add_action( 'pre_get_posts', 'my_custom_ordering' );
erickimani
thanks
erickimani
For taxonomies I created such as this one called regions, it didt work. Text is still showing
Take a look
Custom taxonomy archive is not included in the PHP code, you can modify the code to this:
function my_custom_ordering( $query ) { if($query->is_main_query() AND !is_admin() ) { if ( $query->is_home() || $query->is_category() || $query->is_tag() || $query-> is_tax() ){ $query->set( 'orderby', 'modified' ); } } } add_action( 'pre_get_posts', 'my_custom_ordering' );
erickimani
Sorry it doesnt work I am getting an error message
that means you have more than one snippet that uses the same function name.
Change Yings latest code to something different ie.function my_custom_ordering_two( $query ) { if($query->is_main_query() AND !is_admin() ) { if ( $query->is_home() || $query->is_category() || $query->is_tag() || $query-> is_tax() ){ $query->set( 'orderby', 'modified' ); } } } add_action( 'pre_get_posts', 'my_custom_ordering' );
