Effects and smooth scroll questions
    I’ve added some effects to headlines and I used the copy and paste styles for each to make sure they were the same. On the front end however, the two top ones are scaling from the center as expected, but the rest of them are scaling only from one side. I’m scratching my head here as I can’t find any settings that differ. Is it a bug or have I done something wrong?
    I’m also wondering how I go about getting a smooth page scroll down to the anchor link rather than a skip as it is now.
    Thank you!
    Copy-and-paste styles can sometimes have quirks. I suggest duplicating the entire block to create an exact replica.
    For smooth scroll implementation, refer to this article:
    https://docs.generatepress.com/article/smooth-scroll/
  • Hi Alvind,
    I’ve duplicated them and the issue still remains.. I’m not sure what to try now?
    Thank you!
  • I’m not sure what went wrong, I inspected both hover CSS rules, and they appear to be the same.
    When you duplicate the working heading and replace the one with the incorrect hover effect, does it still not work?
