jyotsna4amit
I have created a block element (hook) for home page design.
However, it it not getting applied to the home page. The home page still shows an old design. I am not sure what else to change.
Could you kindly check this?
I’m not able to open the login link, so I can not see the element settings.
Can you make sure the location of the element is set to
front page?And what hook name are you using?
jyotsna4amit
Hi Ying,
I am able to open the link with the given TEMP credentials. I just tried that in INCOGNITO and it worked. Please try.
Screenshot of the setting: https://postimg.cc/9z2Jw3jq
jyotsna4amit
I selected the Element type as ‘Loop Template’ and it worked. Is this the right option?
yes, it is ok to use that setting/
The alternate was to NOT use a GP Element and just build the layout on your static Home page… -
jyotsna4amit
Hi David,
Thanks for your input.
Now that I have used it, will there be any problems using the Element for home page?
Also, is there a way to convert this element into a static home page?
No, it’s ok, just building it directly on the homepage is easier to manage.
You can do so for all static pages.
You can copy all blocks from the element and paste it to the static page. If you don’t know how to copy/paste blocks, please check this video:
jyotsna4amit
Hello Ying,
I was able to copy this to the homepage, thanks!!
However, my homepage editor looks cropped from left and right. Any reason? https://postimg.cc/Ff6vQGwM
Regards
The editor matches the front end layout and width, I don’t see any issue.
Let me know if i miss anything!
jyotsna4amit
Hello Ying,
My editor setting still doesnt accurately resemble the page. Due to this, making changes and testing is getting difficult.
Please see this editor view: https://postimg.cc/XB7XkSLx
This is the page view: https://postimg.cc/t7X1jWbP
Kindly help. Temp creds are mentioned in the private section.
Thanks a lot!
