Element Grid Query Loop
  • Hi GP,
    I’ve been using ACF to build “archive” pages using the element since I need to add specific meta data. I saw that you recently re-tooled the Query Loop with more options, and I thought I’d like my design(s) to be 2 columns or a magazine style grid.
    But when I try creating a grid it brings in just the standard meta data. ie: featured img date, title, etc. But none of my custom stuff. It’s the same when i try building a Q/grid on a simple page and not in an element.
    Am I missing a step or is a 2 column layout out of the question?
    Hopefully this makes sense.
    You need to manually add the custom fields data into the query loop for it to show up. I’m assuming the two-column grid block you’re referring to is the layout option that appears when you add the Query block?
  • I’m assuming the two-column grid block you’re referring to is the layout option that appears when you add the Query block?
    Right. I’ll give it a try.
    Update: Got it. Thanks… No different than the 1st one I built it’s been so long I just forgot.
  • No problem, glad to hear that! 🙂
