riverman
Greetings, I’m using the imprint site from your site library. When I show a category of products and use the before and after element to scroll to another product, how can I contain that scroll to just that category that I’ve chosen and or I’m currently in? At the moment as I go right or left it begins to show all products and not just that category.
fernandoazarcon2
Hi Riverman,
The category archive should only show products from that category. Can you share a link to a category page of your product?
riverman
Absolutely. Here’s the url. https://kencasadyart.com/
Click on Zion National Park, then click on #2 and then start scrolling, this is where it shows artwork from other categories instead of staying in that category. Probably and Element design and that’s where I need your help. Thanks!! -
Can you try modifying the code in the hook element to this?
<?php $current_post_id = get_the_ID(); $category = get_the_category($current_post_id); $category_id = isset($category[0]) ? $category[0]->term_id : 0; echo '<div class="prev_next_buttons">'; $previous = previous_post_link('%link', '←', true, '', 'category', $category_id); $next = next_post_link('%link', '→', true, '', 'category', $category_id); echo $previous; echo $next; echo '</div>'; ?>
riverman
Same result. Do I need to change the display rules?
fernandoazarcon2
Can you share admin login credentials through the Private Information field?
riverman
Yes, listed below.
Can you try this instead? It’s actually more complicated as I thought, here’s the updated code.
Or you can try creating a block element – post navigation, it has the built-in option to choose the same category.
<? echo '<div class="prev_next_buttons">'; // Get the current product global $product; // Get the product categories $categories = wp_get_post_terms( get_the_ID(), 'product_cat', array( 'fields' => 'ids' ) ); // Query for the previous product $previous_product = get_adjacent_product( 'previous', $categories ); if ( $previous_product ) { $previous_link = get_permalink( $previous_product->get_id() ); echo '<a href="' . esc_url( $previous_link ) . '">←</a>'; } // Query for the next product $next_product = get_adjacent_product( 'next', $categories ); if ( $next_product ) { $next_link = get_permalink( $next_product->get_id() ); echo '<a href="' . esc_url( $next_link ) . '">→</a>'; } echo '</div>'; /** * Get the adjacent product within the same category * * @param string $direction 'previous' or 'next'. * @param array $categories Array of category IDs. * @return WC_Product|false The adjacent product or false if not found. */ function get_adjacent_product( $direction, $categories ) { $product_id = get_the_ID(); // Get the query arguments $args = array( 'post_type' => 'product', 'posts_per_page' => 1, 'post_status' => 'publish', 'orderby' => 'menu_order', 'order' => 'ASC', 'tax_query' => array( array( 'taxonomy' => 'product_cat', 'field' => 'term_id', 'terms' => $categories, ), ), ); // Set the order direction based on previous or next if ( $direction === 'previous' ) { $args['order'] = 'DESC'; } // Set the offset based on current product $current_key = array_search( $product_id, $categories ); if ( $current_key !== false ) { if ( $direction === 'previous' ) { $offset = $current_key + 1; } else { $offset = $current_key - 1; } if ( isset( $categories[ $offset ] ) ) { $args['offset'] = $offset; } } // Query for the adjacent product $query = new WP_Query( $args ); if ( $query->have_posts() ) { $query->the_post(); $product = wc_get_product( get_the_ID() ); wp_reset_postdata(); return $product; } return false; } ?>
riverman
Thank you Ying. Your response has now thinking about a redesign, which is probably what it needs right? Thank you again!
I would definitely recommend trying creating a
instead of the code.In that way, you can define your own style and functionality 🙂
