Youssef
Hello team
I will need some help on the Elements.
I have issue with Login | Register Block – Hook generate_menu_bar_items.
I do not know from where to change Prime and change GP | GB | WOO also the link goes to : https://gpsites.co/prime/account/ which is not my site
Please see : https://postimg.cc/kRw4KJx8/aa0c35cbI have made change on Search in header | Block – Hook generate_after_header_content
Please see : https://postimg.cc/7G9XRR04I have done many changes : but unable to modify
Image 1: https://postimg.cc/crPqTKdm | https://gpsites.co/prime/account/
Image 2: https://postimg.cc/2bTRx25b | https://mejulia.com/account/So how could I make change please ?
regards
Youssef -
Hi Youssef,
Can you share admin login credentials through the Private Information field so we can take a closer look?
Youssef
Hello Fernando
Hope all is well with you this morning π
I am re doing a fresh installation of all my elements , once finished i will share credentials in private.Regards
YK -
Alright! Hope to hear from you soon! π
Youssef
Hello Fernando
I’m neither a developer nor a coder. I’m just a person who learns from experience.
I’m really disappointed and I’m throwing in the towel. The template is driving me crazy.
The pages exist: but they’re not displayed, e.g. privacy policy
The problem at Element level is the same, please see the photoI’d be grateful for any help
1. Open “Login | Register” in Appearance > Elements.
2. Select the link, and replace it with the correct Account page on your site. Example: https://share.getcloudapp.com/mXuGoB26
Currently, it’s still linked to our sample site which is causing the issue.
Youssef
Hello
Thank you for the link
https://gpsites.co/prime/account/ by what should i replace it please ?Also what about the ages that do not displayed
the page exist
url :https://mejulia.com/privacy-policy/
when you click on it it’s not displayed
page is set to “Published”
permalink settings: “Settings” > “Permalinks” >Post name
no new plugin installed
Clear cache: donePlease help
Thank you in advance
YK -
Hi YK,
That page is usually created by a plugin. For instance, WooCommerce automatically creates one. Do you have a plugin for this like WooCommerce? If so, I believe the end-point for WooCommerce is something like this:
https://www.YOUR-URL.com/my-account/
Youssef
Hello
Yes I have a Woocommerce plugin.
Ok I do right now modification.What about the page Privacy-Policy
this page and other i have an error message when i click on them
these are my checks :— Switch to a default theme “Twenty Twenty-Three” : the page link : https://mejulia.com/privacy-policy/ exist but when you click message do not appear 404
This page could not be found.
— Page visibility settings: on public
— Page.php: does not contain any specific code that would block pages from being displayed.
— Check for page slug conflicts: there is only one page page / one slug privacy-policy
— Re-save permalinks: are configured on Post name
— .htaccess file: does not include anything that would specifically block pages from being displayed. The code mainly consists of directives related to caching and optimizing website performance using the LiteSpeed Cache plugin.Regards
Youssef -
Youssef
Hello Fernando
The theme do not accept my change : and it’s more complicated
I have made the change as recommended and you can see the results
https://postimg.cc/RW2cpkSWI checked all pages : Woocomemrcecreated a new page
https://postimg.cc/xJNHvtDK/95409b88I paste the link on hook element , but still have issue
Could you help please
and more no page is displayed ? why those issue ?
Please help
Regards
Youssef -
have a look now.
Is it working correctly now ? -
Youssef
Hello David
No it’s not working correctly.
I am sad, i am not a developper or coder , so I can not touch the code.
May be when installing a package issue
well to do not spent time in searching the root cause i decided to rebuild from scratch
π for a second timeRegards
Youssef -
And did you get it working now ?
Youssef
Hello David
I will share with you the results sooner π
Regards
Youssef -
OK. glad to heat that!
