Search for: Element showing inside generate_inside_navigation only on sticky header Scribble May 26, 2026 at 7:50 am Hello, I’m trying to hook an element inside the editor, but I can only see it in the Sticky Header: The hook is generate_inside_navigation. Thank you Ying May 26, 2026 at 8:17 am Hi there, Try using the menu_bar_items hook instead. Scribble May 26, 2026 at 8:49 am Works perfectly. Thank you! Ying May 26, 2026 at 8:53 am No Problem 🙂 Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic.
