Stefan
Hi, I just notice that an element block shows full width in 3840×2160, header and body are ok, as it center.
But one element stretch all over, reading
topic https://generate.support/topic/container-width-in-an-element/The settings are moved to the Sizing panel, you can set max-width for a container, eg. 1140px, or simply click on the earth icon, it will fill the field with the value that’s set at GenerateBlocks > settings > GLOBAL MAX-WIDTH.
This works, but part 2,
And to center a contained container, you can set its left-margin and right-margin to auto.
Does not, it sits to the left site, any idea why?
Thank you
Hi Stefan,
The left and right auto margins need to be applied to the same container where you’ve set the max width. Right now, they’re applied to its wrapper, which is why they’re not taking effect.
Stefan
YES, Thank YOU!
So easy =) -
You’re welcome! 🙂
