Puneet-Gogia
I have a few elements that are not showing on the page.
https://prnt.sc/lwC_y-GqMJgg -
Could you please elaborate on which setting isn’t showing? I checked one of your Elements and can still see the Block Element option.
Let me know if I’m missing something!
Puneet-Gogia
It is not showing anywhere. You can check any of the elements that I have that are not showing with any of the settings.
Please help!
Here’s what I’m seeing: https://cln.sh/zphWRMJF
I don’t see any missing settings at the moment. If you could specify which setting you’re referring to, that would be helpful.
Puneet-Gogia
Thanks for checking!
Let me clarify the issue: I’ve created a few Elements using the Block Element type, and I’ve set specific display conditions for them, like showing them on a certain part of the page, like above or below the title.
However, even though I’ve configured everything correctly (location, display rules, etc.), the elements are not appearing at all on the front end of the site.
See this one, which is configured to show below the title of the pages, but it is not showing:
I see, yes, the settings seem to be correct, and the breadcrumb should’ve shown on page under the title.
Is the content inserted via a custom HTML block? Can you add an empty paragraph block below the HTML block to test?
