Elements — Editor width not working
  • I have a brand new install that I can’t get the “Editor Width” in any Element to work as before. See this screenshot:
    https://share.cleanshot.com/ykpMQ4Yf
    The width stays at 100% of the block editor no matter what I put here.
    I’ve included access to an InstaWP site I spun up for testing this in the Private Information area — I also tested locally and have the same issue.
    Any ideas?
    I can replicate the issue on my end; it seems like a bug.
    Thanks for reporting it to us.
    For now, you can use this code to manually set a max-width for GP element’s editor. I’ve set max-width to 500px, you can change it to fit your needs.
    add_filter( 'block_editor_settings_all', function( $editor_settings ) {
        $css = 'body.block-editor-iframe__body.post-type-gp_elements {
        max-width: 500px;
        margin-inline: auto;}';
        $editor_settings['styles'][] = array( 'css' => $css );
        return $editor_settings;
