Elements not possible to edit
  • Hey, I have GP Premium (theme and plugin both last update), WordPress 6.7, when going to the Elements and wanting to change between the “Seitenkopf”, “Page Hero” etc. (see screenshot), nothing happens. I click it, and nothing happens. Both the same with existing Elements or newly created ones. Obviously in the past it worked fine. I already deactivated all other plugins, its not that. Any solution to this? Because else I dont need the GP Pro plugin I just renewed…
    https://www.dropbox.com/scl/fi/pikp9ak7tjj34z8dwv0to/Screenshot-2026-05-25-221525.png?rlkey=93y04ld9mb2ffarertqs5ztc2&dl=0
    I’m not sure what you mean. The screenshot looks normal when the page hero tab is active.
    Let me know if I miss anything.
  • Yes, but I cannot click on any of the other tabs (Seitenkopf / Anzeigeregeln). If I click on it, nothing happens.
  • I see.
    Can you provide an admin login for me to check the issue in the backend?
    You can use the private info field.
