bekekitti
Hi!
All of our embedded vimeo videos are not visible if GP Premium plugin is turned on.
A made a screenshot video to present the bug:
https://www.loom.com/share/fa8e83499c9449a3989fb6b6222740f4?sid=fe5b2726-0ae5-47e5-b217-86902dfbf79aCould you please fix this?
Thank you for your help in advance!
Kitti -
Can you link us to the page in question?
And while we are checking, can you disable all other plugins except Elementor and GP Premium to eliminate conflicts from other plugins?
bekekitti
Hi Ying!
This is the case for all of the learndash lessons, eg. https://raczgreta.hu/kurzus/itt-kezdd-alapok/lecke/hogyan-gondolkozz-a-taplalkozasrol/tema/mi-az-az-egeszseg-miert-torekszunk-ra-azon-kivul-hogy-sokaig-eljunk/
You can disable what is needed during the troubleshooting.
in Appearance > Elements you have a GP Hook Element called
Cookiebotand that is causing the issue.
I Quick Edited that element and set it to Draft and now the Video loads correctly.You would need to check with the cookiebot script provider on what is causing that issue.
bekekitti
Hi David!
Thank you very much for the quick and effective help! I’ll contact Cookiebot to troubleshoot further.
You’re welcome!
