So, I discovered something on my site. When emojis are used within paragraphs in the post loop, no problem.
Within a local pattern based on global styles, an emoji that is supposed to show up at the end of a sentence with the rest flowing afterwards turns the first sentence into a column, the emoji into another column and the rest of the text into a third column.
What the…
This didn’t happen before and I can’t identify a change on my side that may have triggered this – except that I suspect that upgrading to GB 2.0 really didn’t help.
In the private info is the link to a test post to show the problem.
Are you referring to the fire emoji?
If so, I do not see the issue. This is what I see:
https://app.screencast.com/zYDAUWhtcvnAcLet me know if I miss anything!
alesia
I really don’t understand that. Tried it with multiple browsers here and I see something totally different than you do.
I’m using Chrome.
I also checked your site with Firefox, it looks normal as well:
https://app.screencast.com/dEbA4jhMd038i
