I used to copy the contents of a Generate block pattern and paste them into my WordPress blog, but I don’t see that option anymore. I upgraded to the Generate One subscription, hoping it would solve the issue, but it hasn’t. I just want to copy a pattern and paste it into my blog. You can see how I used this option in the past to create a hook for my footer on this blog, for example: https://thegoldenlamb.com/coffee-questions/are-coffee-bags-recyclable/
The block or pattern I copied and pasted into a hook element is at the very bottom of this blog post, showing recommended posts. Where is the library where I can grab content from?
Are you referring to the legacy pattern library? If so, you can still access it here: https://generateblocks.com/legacy-library/
Ah yes, precisely. Thank you.
How am I supposed to use the new library?
Thank you, both!
No Problem 🙂
