Enable search modal in primary navigation
    I tried some other places for primary navigation. Now I turned back to the place below header. But search modal doesn’t appear though it is activated. I cleared the cache, too.
    Website: https://geraldlanger.de
    What to do?
    Best regards
    Gerald
    Can you disable the search modal, publish the change, clear cache, and then re-activate the search modal, does that work?
    And please also try disabling all plugins except GP premium in case there’s a plugin conflict with the search modal function.
  • Hi Ying,
    thank you for your answer.
    But no success this way.
    Best regards
    Gerald
  • Can you provide an admin login for us to check the backend?
    Please keep all plugins deactivated during our inspection.
  • All plugins without gp premium?
  • Problem solved – I did some adaptions in the customizer (general)
    Thank you!
  • Glad you got it sorted 🙂
