Error in GBlocks accessing dynamic data from ACF options page
  • Hi generators.
    I get the error message “This block has encountered an error and cannot be previewed.” when I try to insert dynamic data from an ACF options page into a GenerateBlocks-Block. More specificly the message appears as soon as I click into the “META KEY” drop down field. No errors from other ACF sources.
    Temporary Screenshots
    Meta Key drop down
    Error Message
    (no caching, all plugins deactivated)
    Option is not a valid dynamic tag, are you trying to pull data from ACF options page?
  • Hi there.
    Yes, I try to pull data from an ACF options page and “Option” in the drop down seemed to be the right fit.
    You need to specify the option key as well for it to work.
  • Hi Alvin, like I wrote: as soon as I select the “META KEY” drop down field, the block breakes. Error message in attached screenshot.
  • Sorry, I missed the part where you mentioned that. I can’t replicate the error on my end.
    If you try editing the tag directly like this: {{option key:option_field_name}}, does it work?
  • Thx Alvind, this actually works. Just if I try to access the meta key dropdown. Maybe something got screwed up when i exported from my local staging to the current server. I’ll work on it like this for now and see.
  • Glad to hear that! 🙂
