digital now
hi team, got an error in the creativework schema, (tabindex=0) url and screenshot attached.
any idea? -
It does not look like added by GB, do you have an SEO plugin?
if so, can you disable it to test?
digital now
yes, i use the seo framework, but the error is still here after deactivation and cache clearing…
Could you try selecting the Headline block that has the
itemprop="tabindex=0"
attribute on it? Then, go to Advanced > Custom Attributes and check if any attributes are set there. If there are, just remove them. -
digital now
hi alvind, yes there is a custom attribute, but we need this for accessibility.
https://web.tresorit.com/l/jJQCp#hm4zU7s7f3Vu3uZ2KErcHA -
that data attribute will add this to your HTML:
Which is not a valid schema so you need to remove it.
In the current version of GB you can’t add the tab index property.
In the GB 2.0 Pro , which is scheduled for release in February, the new blocks do support those attributes.
Can you wait til then ? -
digital now
of course, it`s not this urgent thing.
Glad to hear that
