Error with container block
  • When adding a container block (from GP Blocks), to a page or element in GP Premium, editor shows this error:
    “This block has an error and cannot preview.”
    The same when adding directly a Grid, when click/select each column of the grid that error is shown.
    Thank you.
    Can you disable all plugins except GB? Does the issue persist?
  • Ok, it is solved. Thank you!
  • Glad to hear that 🙂
