Exclude images from the assistive technology
    I would like to exclude decorative images from the assistive technology. I’ve added the attribute aria-hidden=”true” to the image element and I have the title and the alt text empty.
    The tool https://accessibe.com/accessscan evaluates this solution as a failure – Figure elements used to display images should have a role=”none” attribute, and the image itself should provide a description using the “alt” attribute.
    Do you have any suggestions on how to do this, please?
    I’m not an SEO expert, so maybe try following the tool’s suggestion, add role ="none" and the alt attribute.
  • I’m not an SEO expert either, nor am I stupid. In the end, marking the parent container as aria-hidden=”true” helped.
  • Glad to hear that 🙂
