Excluding page categories in Post Navigation element
  • Hi! I am using both pages and posts for creating content in my webpage, so I use the post navigation element in both.
    I have created a category (slug is “interno” and category ID is 1370) which contains some pages I don’t want to show in post navigation element (such as cookies policy, legal information…).
    I have tried adding some code I found in this forum to hide that category, but it`s not working. This is the code I added to functions.php:
     * Remove Post Navigation in categories
    add_action('after_setup_theme', function() {
        add_filter('generate_category_post_navigation', function($display) {
            // List of category slugs to exclude
            $excluded_slugs = ['interno'];
            // Get the current post's category slugs
            $post_categories = get_the_category();
            $post_slugs = wp_list_pluck($post_categories, 'slug');
            // Check if the current post is in any of the excluded categories
            $is_excluded = !empty(array_intersect($excluded_slugs, $post_slugs));
            // If the post is in an excluded category, return false to disable navigation
            // Otherwise, return the original value
            return $is_excluded ? false : $display;
    It’s not working so far so I need to Know what I am doing wrong. Thank you in advance!
    that code will only work with the themes default post navigation.
    And I am not 100% sure on how this will work with an element – but you could try this:
    add_filter('get_previous_post_where', 'exclude_category_from_adjacent_posts');
    add_filter('get_next_post_where', 'exclude_category_from_adjacent_posts');
    function exclude_category_from_adjacent_posts($where) {
        $where .= " AND p.ID NOT IN (SELECT object_id FROM wp_term_relationships WHERE term_taxonomy_id = YOUR_CATEGORY_ID)";
        return $where;
    Replace the YOUR_CATEGORY_ID with the ID .
  • Hi David,
    Unfortunately, the code you provided is not working either.
    Yes, I want to exclude a category of pages from showing in the default post navigation ( this: Block Element – Post Navigation).
    Can you please provide me with the correct code?
  • A block element – post navigation is not the default post navigation of the theme.
    However, give this code a try:
        // Get the term ID of the "interno" category
        $exclude_category_id = get_cat_ID('interno'); // Replace 'interno' with your category slug if needed
        // Add condition to exclude posts in the "interno" category
        if ($exclude_category_id) {
            global $wpdb;
            $where .= " AND p.ID NOT IN (SELECT object_id FROM {$wpdb->term_relationships} WHERE term_taxonomy_id = {$exclude_category_id})";
        return $where;
