I want to extend the Search option (magnifying glass in menu that opens the modal) with 2 radioboxes:
-Broad
-ExactThe code:
<form role=”search” method=”get” class=”search-form” action=”<?php echo home_url(‘/’); ?>”>
<label>
<input type=”search” class=”search-field” placeholder=”<?php echo esc_attr_x(‘Search …’, ‘placeholder’); ?>” value=”<?php echo get_search_query(); ?>” name=”s” />
</label>
<fieldset>
<legend>Search Type:</legend>
<label>
<input type=”radio” name=”search_type” value=”broad” checked> Broad
</label>
<label>
<input type=”radio” name=”search_type” value=”exact”> Exact
</label>
</fieldset>
<input type=”submit” class=”search-submit” value=”<?php echo esc_attr_x(‘Search’, ‘submit button’); ?>” />
</form>In functions.php:
function custom_search_query($query) {
if ($query->is_search() && $query->is_main_query()) {
global $wpdb;// Get the search term and search type from the query vars
$search_term = $query->query_vars[‘s’];
$search_type = isset($_GET[‘search_type’]) ? sanitize_text_field($_GET[‘search_type’]) : ‘broad’;if ($search_type === ‘exact’ && !empty($search_term)) {
// Exact search
$query->set(‘s’, ”); // Clear the default search term// Modify the SQL query to enforce exact match
add_filter(‘posts_search’, function ($search, $wp_query) use ($wpdb, $search_term) {
if ($wp_query->is_search() && !empty($search_term)) {
// Exact match on post titles and content
$search = $wpdb->prepare(” AND (({$wpdb->posts}.post_title = %s) OR ({$wpdb->posts}.post_content = %s))”, $search_term, $search_term);
return $search;
}, 10, 2);
} else {
// Broad search
$query->set(‘s’, $search_term);
add_action(‘pre_get_posts’, ‘custom_search_query’);What’s the best way to override the current search box with this functionality?
Another thing that I don’t like so much in the current search, is that the modal close if you accidentally click outside the modal. I prefer a closing icon and even a full screen modal.
You can create a
block element - hookat appearance > elements, set the element type toSearch modal, then add your form HTML in to the block element via the Custom HTML block.Set the location to the entire site.
Let me know if this helps!
